Audio outputs to SL30 intercom
fvanpelt
My panel-layout shows: - Dynon D100, D120, HS34
- Garmin 496, SL30, GTX 328
- Trutrak Digiflight IIVS
D100 is networked via DSAB.
All seems to work OK except audibility of alarm sounds (general, AOA, altitude, etc.).
How can I make these sounds audible via the SL30 to my headset ?
regards,
Frans
Frans, you'll need an intercom or an audio mixer in the system to hear things from the EFIS. We cannot drive a headset directly.
If you do have an intercom or miser, the audio comes out from the HS34 and goes into your mixer or intercom.
Ratman
regards,
Frans
Frans, although the SL30 does have an intercom (Dynon may have missed that in your post), it's pretty crude. It's a two place intercom that's within the SL30 and looking at the install manual (http://www.canardzone.com/members/PhillipJohnson/References/SL30 Installation Manual.pdf), I can't see a way for you to add an external input from the Dynon to the built in SL30 intercom.
A simple external intercom like a Sport 200 will allow you to add the audio from the Dynon for about 200 dollars. An audio panel like the GMA240 will give you many more options for just a bit more money, about 800 dollars.
