nigelspeedy
I have a 3 screen Skyview setup that I am installing in an RV-8 (2 front & 1 rear). Each of the DB37 harnesses has audio outputs (pins 13,30,31). I have a PS-4000 Intercom. I realise that audio out is not yet enabled but if possible I would like to wire it now whilst it is easy. So the questions at hand are:
1. Can I just connect the audio outputs from a single screen to the intercom or do I need to tie them all together? i.e. will an audio output generated by any device on the network be communicated to all other devices and allow just one connection to the intercom?
2. I see that there is a left and right output but my intercom is mono input. Can I just tie the left and right output together?
3. Can I connect the as yet disabled/non functioning audio outputs to the intercom without any disadvantage until such time as this functionality is enabled. i.e. electrically connect now and software update later?
I hope Dynon is having a good Oshkosh and look forward to future developments.
Cheers
Cheers
