AUDIO SUBSYSTEM FAIL warning message
Sukhoi64
Hi,
Still working on my Skyview installation (2 D1000, SVINTERCOM XPDER, 2 SV COM 8.33, 2 ADAHARS, SV AP pANEL, 2 SERVOS)
On RH display only , I have the warning message: "audio subsystem fail".
I noticed that in case of AP disconnection, the audio alarm is made only if LH display is on. If LH display is switched off, I have no audio warning message.
I have double checked that pin 13, 30 an 31 of each display are properly connected to SV INTERCOM.
I have no idea to fix this trouble...
I think that means that we'll want to see that display. Give our technical support team a call to verify. If you have audio output hooked up already, do you hear audio from both displays? (to test each individually, turn on only one at a time)
Hi,
Unfortunately, I confirm that if I switch off LH display, remaining display (RH) will not produce any audio warning. I will contact by mail Dynon support...
Back
