Auto Pilot Flies Left Wing Low
Bardample
I have an RV7a, with Dynon servos. The plane flies wings level with usually no aileron trim needed, but some R rudder trim with a tab on rudder to keep ball centred.
When I turn on autopilot ( in simple mode) using HSI Track function, the left wing tends to drop (, ball stays in middle), and aileron trim is not adequate to keep wing level.If I switch off autopilot, the plane goes straight back to wings level. Otherwise the autopilot function in simple mode ok.
Can anyone help me with an explanation and how can I solve this issue? JeffR Australia.
Your ball is centered with the autopilot on and left wing low? If you need a little rudder trim, and don't have the ball centered with your feet off the rudders, then the AP will drop one wing to counter the rudder.
Bardample
Thanks for your reply. I shall have to go flying again, level wings on auto pilot and see if unloading the rudder keeps it level.
When I hand fly with ball centred, it’s not apparent to me that I need elevator to keep wings level. The stick seems vertical.
My method is to -
Center the 'ball' n flight at your normal cruise speed.
First step is that the plane should fly straight without your feet on the rudder pedals.
Add a rudder trim tab if necessary. Now you may have a 'heavy' wing so then adjust the rigging or add Aileron trim tab or raise or lower a flap a little.
What you should try to achieve is to get the plane to fly straight & level hands off without diverging - if you do that the autopilot will thank you for it :).
preid
SoCal
The plane flying straight without AP would tell me the plane is fine and to recalibrate the inflight autopilot.
I would do the full autopilot steps, including ground, and inflight calibration to assure that’s not the issue.
what firmware are you running?
Bardample
The latest Dynon. ( forgot the number). I’ll try your suggestion. Thsnks
