The switch connects to Contact 1 on the screens, it does not hook to the servos. If you want redundancy against a screen failure, you can hook all your contact 1's together, or you can just hook to one screen and the feature will work as long as that screen is operating.
I have two screens in the front of an RV-8 and one screen in the back. Can I hook the contact 1 from a front screen via a momentary swithch to ground and then have the contact 1 from the back screen via a separate switch. As opposed to the 'hook all your contact 1's together' via a single switch? Thanks in advance for any help.
Regards
Thanks Dynon for the prompt response. I will hook the level function with a seperate switch from screen 1 (front seat) and screen 3 (rear seat).
Regards
