How do I set up a second amp meter sensor for an auxiliary generator running off the vacuum pad?
J johnsteichen New Member Joined Sep 18, 2010 Messages 227 Sep 23, 2012 #1 How do I set up a second amp meter sensor for an auxiliary generator running off the vacuum pad?
D dynonsupport Dynon Technical Support Staff member Joined Mar 23, 2005 Messages 13,226 Sep 24, 2012 #2 Our products only have one amps shunt, so you'd need to have a switch that switches both the + and - lines from each shunt int our + and - inputs.
