Avmap IV - SL30 and D100
semelton
Cincinnati
no HS34
SL30 communicates with D100. EFIS serial set to SL30/auto but I cannot manage to have the Avmap communicate. I have a toggle switch to select to the SL30 or GPS. Any clues on how to set up the system so the Avmap will communicate?
I set the Avmap to NMEA and the basic required codes but does not output to the HSI.
thanks,
Steve Melton
RV-9A
It's been a while since we've troubleshot an Avmap connection, so I'm not sure if anything's changed with their software. But it used to be that you needed to have more recent software, and that you needed to use "processed" NMEA output on the Avmap end. Here's an old discussion on the topic: http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1241831122/7#7
thanks for the reply.  Last night I did some wiring troubleshooting and determined it was my Rx connector at the AVmap that was not correct.  After correcting and setting the Dynon to Auto/Auto for the serial input it works fine.  Toggling between the SL-30 and the GPS panel switch now displays properly on the Dynon HSI.  The Dynon recognizes each unit automatically. Great feature!  thanks again for your reply.  Dynon D100 impresses me more each day.
Back
