I've got an OAT sensor hooked up to a D120. The sensor's reading 100F, while the actual air temp is more like 60F. If I warm it with my hand it'll go up a couple degrees, but that's it. Everything seems to be setup correctly on the D120. Changing OAT sensor types doesn't seem to fix it anyway. I can't find any menu for calibrating the sensor, if that's possible.
I measured 5.9K Ohms between the blue/white and yellow wires (blue and white are connected to the same pin on the connector). I've got another plane here with the same setup and the same resistance (haven't powered it on yet to see if it's acting up also).
