Barometric Pressure
AlanR
UK
Hi,
I am just at the deciding which route to take stage. If to go for the 10A or 180 or whatever. I am also definitely a novice at dealing with all this advanced technology ...so go easy!
Can you tell me if the barometric pressure can be changed on either of the above units from inches to millibars for us European guys? Is this just an initial  setup procedure to change it?
Alan.
Yes, all units on the systems can be changed between many settings. The altimeter, in particular, can be inHg or millibars. It's a single button press to switch while you are setting the baro and can be done at any time. The unit remembers this setting until you change it again.
AlanR
UK
Thanks for the quick response.
Also apologies for not posting the question in the correct EFIS section.
Alan.
