Base to Final
N342P
prc
Many experienced pilots lose their lives when they overshoot the centerline of the runway usually due to a tailwind on base.  They
push bottom rudder and pull on the stick to "bring her around" and spin into the ground.    AOL might help but what we really need is an alert when the airplane is in a slow skidding turn...  Is there not the capability of such an alert with the Skyview...
The best feature to save lives and nobody else does it$$$$$$$
krw5927
AOL might not help but AOA certainly will. :D
Really though, AOA is the solution, and Skyview already does it. If you don't stall then you can't spin. Airspeed has no bearing on it, as you can stall (and spin) an airplane at greatly varying airspeeds.
