Battery voltage flikring at idle RPM
Akash408
Hi dynon..I am using 28 volt alternator and 24 volt battery.this was not happens before.at idle RPM which is 850 to 950 battery voltage flikring 21 volt to 24 volt.i replace battery and alternator but problem is still there.this problem only happened in flight and not repeat on ground
Electrical gremlins can be tricky to troubleshoot. I recommend you reach out to our support team directly for help with this issue. Contact information is in our signature.
