Bearing info with GNS430
N127RS
My system consists of a GNS430W, HS34, D10A, and EFISD10.  I also have a TRUTRAK Digiflight IIVSVG, with coupled vertical guidance on GPS WAAS approaches.
Everithing is working well except that I ge no bearing iformation on my HSI display.  I press the Bearing source button on the HS34 and turn the Value knob, but absolutely nothing happens.  My Garmin settings are as follows:  (I'm including all screens, realizing many are not relevant.)
Main Arinc Config
  in 1: speed=low; Data=EFIS/Airdata
  in 2: speed=low; Data=off
  out : speed=low; Data=GAMA429
  SDI=Common
  VNAV=Enable Labels
Main RS232 Config
  Channel 1: Input=off;  Output=Aviation
  Channels 2,3,and4: Inputs and outputs off
Main System Config
  Confugure=Fuel
  Fuel Type=AV gas
Main Inputs 1
  OAT=--- SAT=--- TAT=31c IAS=--- TAS=0 WSPD=---
  HDG=162 WDIR=--- BALT=180 DALT=----- PALT=184
Main Inputs 2
  LFF=----- RFF=----- TFOB=----- GPSSC=000 VLCSC=--- CDI=VLOC
  JOYSTICK WPT=---- ----
Instrument Panel Self-Test
  LCDI=Half Left LFLG=Out of View VCDI=Half Up  VFLG=Out of View
  TO?FROM=To RMI=135 OBS=--- ANNUN=On DTK=150
  CAP=0 FOB=---- FF=----
Main Lighting
  LIGHTING DISPLAY=8802  KEY=400
  SOURCE DIPLAY=PHOTO KEY=PHOTO
  RESP TIME/MIN DISPLAY=4 080  KEY=4 40
  SLOPE/OFFSET DISPLAY=50 50  KEY=50 50
GPS Date/Time
  UTC DATE=11-JUL-10   UTC TIME=15:45:01
Main Discrete Inputs
  GRAY CODE=0   DECODED ALTITUDE=---
  EXTERNAL SIITCH STATE: No boxes highlited
Main Discrete Ouptuts
  DISCRETE TOGGLE=APR
  ILS/GPS APR box highlighted;  all other boxes not highlited
Main CDI/OBS CONFIG
  LAT: CDI=Center  Nav Flag=Hidden   To-From=Hidden
  VERT: CDI=Center   Nav Flag=Hidden
  SELECTED COURSE= ---.- No input
  CDI=VLOC  OBI SOURCE=Track CDI  V-FLAG STATE=Normal
Com Setup
  FREQ=122.800  SPACING=25.0 kHz
VOR DISCRETE INPUTS
  REMOT XFR Box not highlited
VOR/LOC/GS CDI
  LAT: CDI=Center  FLAG=Hide S-FLG=Hide  TO-FR=Hide
  VERT: CDI=Center  FLAG=Hide  S-FLG=Hide
  SELECTER COURSE= 000.0 Calibrate to 150?
  DME CHANEL MODE= Narco 890/891
VOR/LOC/AG ARINC 429 CONFIG
  SPEED: RX=Low   TX=Low
  SDI=Common
  DME MODE= Directed freq 1
GPS VOERICAL OFFSET
  GPS ANENNA HEIGHT ABV GND=4.0 ft
I received a replacement HS34 from Dynon, but it acts the same way: no bearing pointer and (---) on both the bearing sources.  Presiing the bearing source button and rotating the Value knob has no effect.
Can anyone see anything wrong with my settings?
Thanks and best regards,
Rafael
You probably ought to give us a call at 425-402-0433 when you're at the airplane for some more personalized troubleshooting, but, even if the 430 were completely off, you should still be able to see the BRG sources change on the HSI page when you push the BRG SRC buttton once or twice and spin the knob - it will go through the various GPS/NAV sources that are configured in the Dynon unit's HSI setup. So another thing - if there isn't anything set up in the Dynon menus, neither the BRG SRC nor the NAV SRC buttons would do anything.
Now, if your HSI works but the BRG doesn't, then that's a little weird. Anyway, give us a call.
