Hi
i am rebuidlng my panel and i am installing a D10A i had on another a/c
i am testing the pitot and static lines, pitot tests goes ok, i pressurize the line and i see a speed increase according to pressure applied
i tried to test the static port but applying positive or negative pressure the ASI also shows speed, and the pressure and altitude indicated slowly equalizes wiith ambient and retuns to zero. this happens also with a direct connection to the EFIS so is not a leakage in the lines.
is this normal behaviour for the static port or is there a problem with the EFIS?
thanks
thanks
