What is the difference between the "Black Box Log Data" and the "User Log Data" files for a particular flight? I notice these files are often split up into several parts but there is normally one that covers the entire flight.
Recent Flight Data Log
The Recent Flight Data Log captures the most recent 15 minutes of flight at a data recording rate of 16 times per second, in the same manner as described above. Its recording rate cannot be changed.
The Recent Flight Data Log records data whenever SkyView believes that it is in flight, which it determines by observing IAS and/or GPS ground speed.
After my last flight I repeatedly timed it and did not receive the same result twice. Once it took approximately 55 seconds! (This is why I requested separating the download of the User File from the Black Box File.)Exporting it only takes about 7 seconds, so it's not really much of a waste of time to do it in parallel with all logs, but we can consider that if it is an issue for customers.
Today I started a download as soon as I cleared the runway and it finally finished as I neared the end of my taxi -- certainly more than 7 seconds, probably more than 60. It doesn't always take that long but when it does, it's an issue.Exporting it only takes about 7 seconds, so it's not really much of a waste of time to do it in parallel with all logs, but we can consider that if it is an issue for customers.
