Booting with 13.03
SuperCub
Since I have installed firmware 13.03 I´m having an issue with booting the second screen.
It is a dual skyview system and I boot screen #1 with the backup battery - no problem. After engine start I switch on the avionics master and every now and then the second screen hangs somewhere in the booting sequence. No switching possible, however pulling and resetting it´s circuit breaker let it boot normally.
What version were you coming from? Can you get in touch with our support team directly at 425-402-0433 or at support at dynonavionics dot com?
SuperCub
I came from - not sure - 12.02 or so. The latest version before 13.0. which I did not install.
