Both Servo's no longer visible on the DSAB
GW0820
Looking for some help. Both servo's no longer visable via the DSAB. D100 EFIS, AP74, and D120 EMS are all visible on the bus. Checked to verify the DSAB wires were connected to the EFIS. The pitch servo (SV32) also seems to be engaged when ever the aircraft is powered on. The aileron servo (SV42) not so much.
Do they both get fed from a common set of DSAB wires (IE, a single leg to both servos that then splits). One thought here is to disconnect the servos one at a time to see if it's one of them causing the issue discretely.
GW0820
Thanks for the reply. They are wired to a common set. I did disconnect each one at a time with no difference. One thing I just thought of yesterday, but haven't checked was the voltage to the servo's, as they share the same circuit breaker. But still curious to why the servo seams to have power on them.
