Built in Battery Appears Dead
oredig75
In the process of installing the D100 EFIS, I have run the internal battery down. Do I need to return it to the factory or will it recharge when I am up and running the engine and receiving a charge from the alternator.
Steve
RV 7A
Finishing
Hi Steve,
Any time master power is present, whether or not the unit is actually turned on, the internal battery charges. If you bring up the voltage "info item" on the main EFIS screen when the EFIS is on, you can actually watch the "I" (for internal battery) voltage level increase as it charges. Note that from a completely dead state, it can take as much as 10-12 hours to fully charge the battery on master power.
