Can a add a “canopy open” warning to my RV-12?
glenadavis
Solon, Maine
My RV-12 does not have the micro switch and interface with the Dynon to warm me if the canopy is not latched. The RV-12’s if seen made at the factory do have it. Is there a kit I can buy to add it? Mine is experimental.
GKC Aviation
You should be able to buy the switches from Vans to suit the RV-12.
Pretty simple to wire up to the Dynon general purpose inputs.
I would wire a pair from the D37 general purpose input and a spare ground wire, the each side of the switch.
Doesn't matter if you use the normally open or normally closed contact, just configure it in the settings
  • Like
Reactions: RAS
Note that doesn't apply to the D180. You didn't say what model Skyview you have. You can also make your own if you don't want to buy the kit. It also means you just make a small configuration file change rather than reloading system software.
