jacktunnell
- Joined
- Jan 19, 2013
- Messages
- 41
Can AOA widget be moved and size changed?
Skyview Classic
Skyview Classic
I agree. In current position and size it simply is useless. It needs to be as high as possible on the screen and at least 2-3 times bigger. I can only rely on the sound at present, and I agree that it needs the ability to adjust it louder than any other alarms in the system. Meanwhile, the airspeed low warning that appears on the screen is meaningless. It shows up at around 20 mph above my normal final approach speed. Yes, all the correct V speeds are programmed in.I also support Bruce's comments. I'd like to have the display have the features of the EMS vertical widgets with the ability to select marks for best glide, climb rate, climb angle, approach and the current stall indicator. A numerical readout is needed to select the above. Moving the AOA indicator as higher on the screen would reduce the runway to AOA glance time. AOA is a great feature. It just needs a better and more useful presentation.
