A typical ground installation for a localizer antenna array is 100 feet wide. And use for autoland roll-out suggests the signal can be used to within about 1000 feet of the antenna (or even closer).
Does anyone know if an array can be miniaturized to a few feet wide? And the signal used to within a few inches of the array? We are not limited to VHF freq's for the carrier nor 90/150 Hz for the modulation, so we can increase frequency to reduce wavelength and therefore size.
I ask because we are undertaking a school project to guide a spacecraft to an automatic docking collar, and this existing technology would be useful if we could overcome some engineering limitations (like control of the back-lobe radiation and interference of the spacecraft with the signal). But the signal must be useable until docking is imminent.
Thanks,
Neil J.
Thanks,
Neil J.
