Certified GPS signal to the transponder SV-261
N510RL
I am installing a GTN-650 with a certified GPS. How do I connect the certified GPS serial data from the GTN to the Dynon SV-261 TXP pin 3 so I have a certified GPS signal for the ADSB outputs? What pin or pins on the GTN unit do I use.
Roger
Roger
Connect as per the Dynon install manual, Section 11 with diagram on page 11-8. ;)
More specifically, one serial port from the GTN is used for this purpose. If you have an Arinc converter as well then another serial port is connected to that.
HTH
Jake J
