rogersmart
- Joined
- Aug 4, 2008
- Messages
- 107
It may just be me but I have a problem with inadvertently changing the baro setting by accident, thinking I am changing the heading or altitude bug when the same joystick is in baro mode. Yes I know this is an operator error not a systme error, but I would like Skyview to help me out. When ATC gives a new altimeter setting, a positive action should be required by skyview to enter the baro change. I see no productive reason for the joystick to remain active in baro mode after the adjustment is completed. I would like for the joystick to automatically go dead or switch to previous mode such as heading 5 seconds after the baro change has been completed. One option would be to have and require a hot key set the joystick to baro (instead of current method) for a fix amount of time or until the setting is completed then switch back to the previous mode whatever it was. It would be more intuitive for me. I think it also can be a safety issue. If ATC gives you a new altimeter setting while in terminal area, work load is high, and you and leave it in baro mode, you could inadvertently reset the altimeter to read much higher than actual at a critical time creating an extremely unsafe condition. That one joystick controlling so many modes can be difficult in a high workload situation. It needs to be harder to change the altimeter setting.
Anyone else have this problem or have thoughts on this issue?
Dynon, do you see any merit to my concerns?
