Let's say I'm cruising along at 6000' in ALT HOLD mode and I want to climb to 8000'. As best I can tell, these are the steps required:
1. Select ALT bug on left joystick knob
2. Set ALT bug to 8000'.
3. Go into Autopilot Menu and set pitch mode to VS.
4. Select VS bug on left joystick knob
5. Set VS bug to +500fpm. Autopilot then begins climbing to capture the new altitude.
[NOTE: If you set VS to +500 before setting the AP to VS mode, the VS bug gets reset to zero]
That is an awful lot of steps for such a simple change. I tried using the NOSE UP and NOSE DN buttons with the autopilot in ALT HOLD mode but they had no effect.
What am I doing wrong here?
Thanks,
Adam Molny
Thanks,
Adam Molny
