I have a Rotax 912ULS serial #6782132 and as per SB-912-066UL I have the new cylinder temp sensors which Rotax says should be labeled CLNT instead of CHT.
I've updated my SkyView Touch with 15.0.4 which says you can now change CHT to CLNT. I located this in the installation manual and changed it but it remains CHT on EMS.
Can anyone suggest what I'm doing wrong?
Also the update says you can change the aurL alert from "Cylinder head temperature" to "Coolant temperature ". I can't locate this at all.
I have a 2014 SLSA and was told by Vans that my plane has the right numbers for coolant temp but that at that time there wasn't a way to change the label to CLNT. Now there is.
Any help would be appreciated. Thanks!
