CHT probe problem
Tuiliere
flying a RV7 in France.
FRANCE
Hello,
One of my CHT probes was crazy after only 30 hours so I change it (under warranty). The second one seems crazy too after only 5 hours..
Can you tell me where the problem should be ?
In advance thank you
Sylvain
The fault is MOST likely the crimp connectors at the probe/loom junction especially if they are the pink coloured ones supplied.  If they are pink then I'd replace them with the AMP brand (red).  In my experience the CHT probes do not 'fail'.
You are using a good double jawed crimper, correct ?
Tuiliere
FRANCE
Thank you Jake for your reply. I have to change the pink colored jonction for this probe.
