CHT Probe Thread Compound
rv7apilot
I'm getting ready to install the Dynon CHT probes in my Lycoming IO-360-A1A. Do you recommend putting an anti-sieze compound on the threaded lock collars that thread into the cylinder heads? If so, what type/brand of anti-sieze compound should I use?
I don't bother with anti-seize for the Cht but any of the anti- seize brands will do the job ;). That's what they are used for.
Jake J
Battson
Bearhawk
If you ever plan on having to remove one of the heads, anti-seize won't make things any harder at least. Hopefully easier. I did use some, just in case, I used some copper based stuff but I don't think the brand really matters.
