CHT READING
AMONTOYA
Hello,
Installed in a 2015 Rotax 912 ULS with Skyview 10"T airplane with 130 hours without problem started to read on R CHT ascending up to maximum temp for 5 second and then comeback to normal range (same as L side) during low RPM operations (taxi and app).
Any suggestion? :) :) :)
Thank you.
Does it go up gradually? Or is it an instant change? If you had the signal wire shorting to ground, you'd have a spike that goes high. The 912 CHT is a probe that comes on the engine (and is not supplied by Dynon), so you'd want to source a replacement for that from a Rotax dealer. But first, I'd probably check the connections.
