Circuit Breaker Size
Mzwijacz
Installing my roll and pitch servos. When looking through the installation guide, chapter 10 "Circuit Breaker/Fuse" it states "We recommend that electrical power for the autopilot servos be protected with an appropriately sized circuit breaker or fuse that is accessible to the pilot while in flight." but does not state the amperage used for a 12 volt system.
The servos I'm using are SV32 but I may need to change the pitch servo to an SV42. I would like to put both servos on a single circuilt breaker. How much amperage will they draw if I use the SV42 ? I need to size the circuit breaker.
Thank you,
Michael Z.
Mzwijacz
Jake,
Thanks, I looked through the appendix and found only one module with the amperage draw. Where should I be looking for the amperage requirements of the Autopilot servos ?
