Class B entrance notification
randylsnarr
Salt Lake City, Utah
I fly in a class b area. I am on 10.0 firmware. Currently when I approach a blue class b segment on the Map , it no longer has the altitude range listed even though that is turned on in map items. That is problem a. I have to use the curser to light up the segment so I get the black tape with the airspace info.
It would be good to have the altitudes back at a minimum.
I would love it if the display somehow told me the the altitude of class b whenever I approach a new segment regardless of map zoom level. I just want to look down and be able to know the altitudes of that segment. It would be cool if you could make the segment glow or change states if you are on a trajectory to pierce class b.
B.Blenden
Oviedo, Fl
I updated to 10.0 several days ago and also have noticed that the airspace altitudes are not displayed on the map. I checked the map setting for AIRSPACE ALTITUDE and it is set to ON. If I pan the pointer into the airspace it will show up, but it used to be displayed on the base map. Is there some other setting that affects this item?
JTD
dallas tx
I had the same problem with class B airspace altitudes missing. Dynon tech support is aware and told me it is a bug they are working to fix
Yep, we are aware of the issue and it will be fixed in a software release out soon.
