Class of airspace information
S5_aero
I would like to know how to check the class of the selected airspace on Dynon SV.
I'am using pocketFMS data and they offer on easyVFR easy lookup for airspace class even showing class on your courent position.
It would be nice to add class of airspace to a popup dialog when you select an airspace on dynon.
preid
SoCal
there is color for each airspace and one can move over the airspace to get the specific information on that airspace.
S5_aero
Yea you have color differentiates and names of airspace but no class.
It would be very helpful if we can see if it is controlled class A,B,C,D or uncontrolled E,F,G
S5_aero
reidvaitor this is exactly what i would like to use
user guide page 7-45 figure 120 when airspace is selected i would like to see this class info.
How can i enable this class information?
when i select the airspace i can only see the name and the min and max altitude.
is this related to data provider? i use pocketFMS data.
Right now there isn't a way to change what is displayed in the pop-up. Class information is possible to show there, but it may be that the way we currently interpret the PocketFMS data, it doesn't populate that field in some cases. Do you never see class information when you select an airspace, or is it only some classes that you don't?
S5_aero
i never see a class information. i only see description like terminal area or control zone. see attached pictures.
