Clock setting on D180
Chad800
When I set the clock as per the instructions (set Zulu time and Local time independently) the display is fine until I switch of the master. When switched back on, the time display always reverts to 00 minutes. The hour stays correct. I am definitely setting the times correctly. Any ideas?
Chadman
You'll need either a GPS connection to set Zulu on GPS lock, or an internal battery (if it's an EFIS) to keep the time across power cycles.
