COMM T8 vs T25
KiwiRV8
I’m upgrading my dynon comm which has static issues
I’ve been offered a T8 as the T25 isn’t available
Any pros and cons between the T8 and T25 ??
wilkersk
The T8 can be set to 25khz channel spacing. So, it would be the equivalent of the T25, with the added benefit that if you need 8.33khz channel spacing, you've got it with just a few button pushes. They're both Trig Ty91 radios that have been configured to work with the Dynon com panel.
Only difference I'm aware of is the channel spacing, as Wilkerson said. Otherwise they're identical.
Correct. They are absolutely identical when the T8 is set to 25 Khz channel spacing.
