Shouldn't be. The Skyview uses a GPS fix to determine declination and variation, which is what changes with location, and then it automatically adjusts based on that. The compass calibration isn't designed for adjusting to changes in location. It's used to compensate and adjust for any magnetic variation from the aircraft itself, which doesn't change with location. You can certainly do one if it makes you feel better though.
