Confusion between skyview, HS34 and other dynon
johnsteichen
I find myself constantly being confused when skyview references are randomly mixed in with references to other dynon equipment, including the HS34
Is there some way the skyview information across the board can be separated from all other dynon references. I never know if information pertains to me or is irrevelant to me
Example: on the Garmin 430 page from dynon docs there is a sentence that says "you will be using the Nav Src button on the HS34 to toggle between nav and gps." Does this also pertain to the source switch on the skyview. I assume it does, but the confusion is there. There is such a mixed soup of comments, and what it pertains to is often unclear through out the entire forum.
PhantomPholly
Re: Confusion between skyview, HS34 and other dyno
It's probably time for Dynon to re-name the forum sections into "Legacy" and "Skyview" for more clarity. I can see where people would jump into the "General" section and not know which units are being discussed.
