Connecting Com-425 to PS Engineering 5000EX
Mzwijacz
Need some help with the connection between SV Com-425 and PS Engineering 5000EX.
Symptoms
Display on SV-Com panel show STUC
Active frequency says 118.500
If I dial in the local ASOS display sometimes shows Airpor ASOS but Active frequency says 118.500 and no ASOS is heard
Dynon frequency displays 118.500
Unable to switch stand by and active frequency
Connections
Com 425 PS 5000EX Com-Panel Comments
Pin 1 J1 pin 15 Com2 mic
Pin 2 Loop to Com 425 pin 9
Pin 3 pin 6
Pin 5 J1 pin 30 Com2 mic key
Pin 6 pin 4
Pin 7 pin 1
Pin 8 Power in
Pin 9 J1 pin 14 Com2 Audio Low Loop to Com 425 pin 2
Pin 10 J1 pin 13 Com2 Audio Hi
Pin 12 Avionics Ground bus
Pin 13 pin 2
Pin 14 pin 5
Not sure what I'm doing wrong here ? I've talked with PS Engineering and they say the connections to the intercom are correct.
Mzwijacz
Sorry the post messed up the formating
Comments
Pin 3 pin 6
Pin 6pin 4
Pin 7pin 1
Pin 8Power in
Pin 10J1 pin 13 Com2 Audio Hi
Pin 13 pin 2
Pin 14pin 5
Mzwijacz
PS Engineering 5000EX Installation Guide
  • PMA5000EX_IM.pdf
Stuc usually means the PTT line is grounded or connected to an incorrect position, despite what the pinouts show - it’s easy to mistakenly put a pin where it’s not meant to be - many of us have done that ;)
Mzwijacz
Finally got this worked out. Seems there were multiple issues.
1. After testing the G430 com, I left the PTT wires temporarily connected to the HOTAS stick. They were connected with knife connectors. These were touching each other, ie. grounding.
2. When stripping the outer sheething from the shielded pair of wires, I bairly nicked the PTT wire 5 going to the intercom. We are talking like 1/128", but that was enough to ground the PTT sometimes. I found this when I put the shell on the dSub. Working one moment, not working the next.
Don at tech support was great in helping me understand the method for finding all of the problems. Now everything is working. 👍
