Hi All or support,
I am having a hard time to communicate my Dynon EFIS-D100 with the transponder GTX327 In order to transmit altitude. I tried two different setups but no one worked.
Any help would be appreciated.
Dynon was always with Format 4 selected.
First setup tried: ( Dynon pin 13 wired with pin 2 in transponder)
RS-232 INPUT OUTPUT
CHNL 1 # OFF Icarus Alt
CHNL 2 # GPS (I tried to change to Icarus Alt but, for some reason, my transponder CHNL2 seems to have only the options GPS and OFF).
Second setup tried: Modified wiring ( Dynon pin 13 wired with pin 19 in transponder)
RS-232 INPUT OUTPUT
CHNL 1 # Icarus Alt Icarus Alt
CHNL 2 # OFF
RS-232
CH1 # P ALT + _ _ _ _ _ _ FT
CH2 # OFF + _ _ _ _ _ _ _
I believe it should work in either channel, but I tried to connect both ways and no one worked. Nothing is shown in the Altitude field above (only dashes).
I also tried to set the Dynon for 10 foot and for 100 foot increments.
Marcel (from Brazil)
RS-232 INPUT OUTPUT
RS-232 INPUT OUTPUT
CHNL 2 # OFF
RS-232
