Yes, I know coolant radiator connections when I see one. You may not be familiar with this application -- it is a Pipistrel Sinus motorglider which I built from a kit. There is a threaded port with a 10mm x 1.5 thread in the riser pipe from the engine to the radiator. The riser pipe is an engine modification that Pipistrel adds to the Rotax engine to accommodate their configuration. It is electrically insulated from the engine case by the hoses from the riser pipe tee to the coolant fittings on each cylinder so a 2-conductor (isolated) probe, which the MGL probe is, is necessary. The engine came with probes for a European Brauniger pfd/ems instrument which, like the MGL which is a LM335 diode, you don't support. I've bought 2 of the Rotax oil/cht temp probes (yes, there's one each in cylinders 2 & 3 plus one in the oil temp port) @ $186 apiece from Lockwood and am quite familiar with them. I repeat my previous question -- Does Dynon sell a 2-conductor probe with the metric thread that will give me coolant temp? Granted it isn't absolutely necessary with the CHT reads -- the D1000 is also GROSS overkill in this airplane, but it is my plane @ that's the way I want it. If so, please tell me how to order one. Or can the LM335 be added to the probe definition file? I've looked at that procedure briefly but not enough to really understand everything that goes in there.
