My D-100 resets on engine start. It is paired with a D-120, which does not do a reset under the same condition (powered by same battery bus). They both do not have internal batteries. Have noticed the battery voltage dip down to 10V during engine cranking as measured by the D-120.
This is somewhat of an annoyance, since I wish to monitor the engine parameters as I start it (the D-120 is facing the passenger).
I have now found the D-100 to exhibit other symptoms. Once, when masters were powered, the D-100 came up no problem, but the D-100 did not start until about 1 minute or so. I though it had died. This symptom has not surfaced again.
Yesterday, I turned on the master power, and subsequently turned off the D100 and D120 since I was doing some configuration work on the transponder (saving battery power). The D100 powered up on its own after about a minute. I turned it off again, and after a couple of minutes, same thing, it powered up on its own.
