aviatorruss
- Joined
- Jan 9, 2013
- Messages
- 2
Hello,
I've searched my brains out but can't find exactly what I need answered. I'm installing a D-10A & HS34 to be used primarily as an EHSI (I've already got a Gemini PFD) to replace my vacuum DG. I have a Garmin 530W w/ analog connections to a G-106A CDI. I also have an SL-30 with analog connections to a MD 200-306 CDI. I am removing the G-106A CDI in this installation as the D-10A (HSI) will replace all the functionality of the G-106A.
My question is...if I want to connect the SL30 to the D10A via the HS34 serial input, will I need to remove/disconnect the analog (resolver, LOC+, etc) wires from the MD 200-306? I would like to keep the integrity of a standalone SL30 radio/CDI for redundancy, but also reep the benefits of using all three(GNS GPS, GNS VOR, SL30 VOR) pointers on the HSI display vice only two (GNS GPS and GNS VOR) pointers. I don't understand the implications of having two OBS sources for the SL30, if that in fact is actually occurring. I'm not even sure I can wire the HS34 with both an SL30 and GNS530W input at the same time, although I can find nothing that says I can't. Thanks for the help in advance
-Russ
-Russ
