Original VDO sender: occasional fuel pressure warnings, becoming more frequent.
New VDO sender: same as above
Mechanical check gauge: consistently showed 1 psi over VDO
New Kavlico sender (15 psi):
1) consistently shows about .5 psi over VDO
2) fuel pressure fluctuates at cruse 3.4 to 4.4, in 10 to 15 second intervals... apparently a more sensitive sender.
3) turning the electric pump on at cruise causes more rapid pressure fluctuation... but no low pressure warnings yet.
** 4) ON FINAL / Power to idle / boost pump on: low pressure warning, pressures very rapidly fluctuating between 1.7 psi and 4+ psi.
Suggestions please?
Suggestions please?
