Greetings,
I originally installed the 2-wire OAT that came with the D-180, and now that I'm in the process of hooking everything up, I've realized that I can't spare the GP input that the OAT would use on the EMS side of the D-180. I've got a 3-wire OAT on order, and plan to connect it via the EDC, so that should fix me up.
I was curious though, why is the 2-wire OAT sent, rather than the 3-wire? It would seem to me that the 3-wire through the EDC is a better choice, since it doesn't use up a GP input. I also can't think of any reason to have an OAT alarm set, which negates another reason for having it on the EMS side.
BTW, I've cut the wires short on the current 2-wire OAT, so I won't be able to send it back. I mention this only because I'm sure you would offer to take it back otherwise.
Thanks,
Rusty (almost all hooked up)
Thanks,
