D1 Heading information
purlee
Am I correct in assuming that the "heading" information displayed on a D1 is actually the "magnetic track made good", in other words, the track over the ground which the aircraft is covering, reduced to a magnetic heading, rather than the actual magnetic direction in which the aircraft is pointing?
The implication of this would be that, if one was, for instance, on a long over-water flight, where there are no landmarks, you would need to pre-calculate the magnetic track required, as well as the required magnetic heading, to ensure that the D1 was taking you in the right direction.
The D1 is GPS ground track. As you say, it's the actual magnetic track over the ground, not where the nose is pointed.
If you were doing a hand flight plan, you would just plan as if there were zero winds. It works exactly like a compass when there are zero winds to push the nose in a different direction than your path. When you calculate your flight plan, you are already doing this since you calculate your zero wind direction and then add a wind correction angle to it. Just don't do the last part ;)
