Hello Support
Looking at buying a used D1 from someone and I'm told that his D1 is unable to locate the satellites unless it is hooked up to the external antenna.It can't connect on the internal antenna only.
So does this behaviour hiding a potential problem or is it a normal behavior for a D1?
Also does the battery needs to be replaced at specific interval on a D1?
