That sounds like for some reason, the settings on your EMS were lost. They're stored in non-volotile flash memory, so that shouldn't happen, but, if there were an anomoly that caused that memory to become corrupt, factory defaults may have been restored. Each of those symptoms you've described relate to a particular setting (option to swap map/tach, pulses/rev for the tach, and the "wrong" fuel pressure sensor setting for your engine, respectively). The installation guide should be your first step (available from http://docs.dynonavionics.com) - literally go through the entire setup chapter. Our technical support can help you with some of the questions you'll probably have too. Based on what you've said so far, you'll need to at least: flip the tach position via SETUP > SENSORS > TACH, change the fuel pressure sensor needs to be set to either type 1 (older VDO style sensor) or 6 (kavlico) depending on which physical sensor is connected (assuming that your engine is carbureted). Your pulses/rev setting needs to be set to halved, and the other things are a little more complex but are covered in the manual.
