Bob_Gordon
- Joined
- Sep 12, 2005
- Messages
- 3
Prior to first flights in my RV6, I uploaded v. 1.13 without difficulty and now have just over 30 hours on the product S/N 1338. At about 20 hours in, the unit would not boot and I would see the blue screen with the Dynon logo for less than a second followed by a black screen for less than a second, and it would cycle like this for 5 or 10 minutes on average. This has happened at least a dozen separate times, and about half the time the screen would come up after a while and run normally. Once when the screen came up it was more black and white with an "altitude indeterminate" warning. It cleared after about two minutes.
These happen even without the engine running and also when run with the internal battery, so I don't think it's a vibration/connector issue. All my electrics are B&C quality, using B&C tools. I have done a few things to try and solve this. I added an avionics switch for the unit so it doesn't have to endure any more engine starts while on. I also reloaded v. 1.13. It worked for about four or five cycles (flights) but just got another event yesterday.
I am taking the unit out and want to know what more I can do to clear this up. I plan to remove and reinstall the internal battery, but is there any kind of reset otherwise? Or should I send it in to you? The only thing I have not done yet is to calibrate the remote compass module, which is hooked up. But I don't think that would cause this......
Bob Gordon
Bob Gordon
