I've finally gotten around to installing my D10 and have some questions:
1. What is the use of the second "master power" connection at pin 14. Does it need to be connected to the same fused power as Pin 1? It seems to work without it being hooked up.
2. The hood of the D25 connector will not fit under the pitot-static-AOA connections of the D10..??? I have the plastic chrome one. Is there a smaller, less bulky one I can use?
3. Is it permissible to shorten the OAT wires to suit the installation?
4. I'm not using the AOA. Should the red plastic plug be left in or removed?
4. What is "External backup power"? I have the internal battery...should be enough..right??
