D100 audio output
Chris_Sinfield
Hi
I have just a D100 installed. The AOA audio tone works ok in my headset when tested.
When I was setting up the countdown Timers I noted that the LH button was a alarm silence, and the RH button was an alarm cancel.
So does the timer also have an audio alarm output that can be wired up to a headset?
Chris..
Without the HS34 or AP74, there is an audio alarm for AOA and altitude alerting for sure, but I don't recall (the manual's ambiguous, and I'm not in front of a setup with audio) whether or not you get a tone when the timer expires. If there is one, it would be on the same audio output wire though. So if you're hearing the AOA alert consistently, I think the answer is no here.
