D100 Bank Zero in Flight?
bmiller269
Is there a way to Zero out the bank in flight or to adjust level for the efis? In a test flight level flight shows a left bank probably 5* Thanks for the input
Is this a new install, or has it been flying for a while? Do you see turn rate on the ground? (the magenta bar just below heading).
bmiller269
Yes this is a new install. Just took a lap around the pattern to test things out. Yes on the ground I see the magenta bar.
So the EFIS has the ability to do some self-calibration, and sometimes new installs can end up a little out of calibration as you've set them up / moved them / etc. After an hour or less of flight that isn't too dynamic (ie not an hour in the pattern) you should see it go away.
