D100/D120
4rjn
Hi all quick question as I am new to all of this. Which unit does the processing for the EFIS. I can view engine parameters on either screen and I am having issues with some sensors going into red for a split second and I would like to know which unit I should focus on. I have already done all of the checking of sensors, wires, grounds, etc... so no need to tell me to look there first as is has been done exhaustively! Thanks Rod
The short answer is "both displays". The longer answer is complicated, but you should get in touch with our support staff (contact info in signature) for further help with this issue.
Thanks for the reply, I have been in touch with your support and I sent logs of what was happening along with a GoPro video. He looked at the logs and had no offer of a solution other then replacing it to see if it is in the unit or from elsewhere. I cannot afford to buy "test units" that is why I am trying to still track down the issue. Thanks again.
Back
