D100 horizon doesn’t align with wings level
Sportpilot
When flying at wings level the EFIS horizon is leaning a bit to the right (or left, can’t remember) Is there a way to calibrate this?
Is there also a way to calibrate the ball?
Regards Roger
GKC Aviation
The D100 has a remote compass module (Magnetometer). The ADAHRS system is inside the screen.
Roll levelling is not adjustable, and is dependant on the screen being mounted level in the aircraft.
Level the aircraft, then run a small spirit level or digital protractor across the top of the screen. If the screen is level with the aircraft but still displays a wing low, then either the internal sensor has gone screwy, or your aircraft is not flying level.
Ma
I think you meant the ADAHRS - the magnetometer has nothing to do with wing level display.
Marc - it’s posted under the D10/D1000 Series Discussion ;)
and yes, my bad re the wings level, as you & GKC said, that only applies to the SV ADAHRS system.
